Blocking exhaust port passage
for the egr hole?..if so than get a piece of metal and drill 2 holes to match the screw hole and put a gasket on and screw it in. epoxy might melt or deteriate and than later down the road fall in the intake and bounce around on your pistons....same goes for the jb weld.
Not the ones in the ends of the heads, the one that goes up the center of the intake. I would like to block it as close to the head as possible to keep the heat out of the intake. I already have a block off plate for the egr itself.
I already have the thermactor holes plugged (with a 5/8" bolt). I am talking about the non threaded holes that goes from the head- through the lower intake -through the upper intake- to the egr spacer. I want to plug that hole in the lower intake where the holes meets the head. It will keep heat out of the intake if I can figure out how to block it off.
go to the hardware store and find a tap that will make threads in it, then find a pipe plug with the same threads and a hex key end, screw it in with a little high temp RTV and you're set. or you could get it welded up.
TfcCDR
09-14-2015 12:08 PM
09-08-2015 05:21 PM
