I have an 88 GT. Other than a crane fireball ignition and a rear-mounted battery, the entire starting system is stock. I thought it was just a dead battery because the car just clicks when I try to start it. But when I go to jump the car it doesn't even bog the other car down when I attach the jumper cables and all it will do is click even after the cars have been hooked up for several minutes. I am using good jumper cables so that shouldn't be a problem. I also tried jumping the car from under the hood by hooking to the cables coming directly from the starter but it caused a huge spark from under the car (near the starter) and I lost all power. Any advice please??? Thanks.
wear did you try to jump it from the starter or the selonoid, if the selonoid check the connections on the starter might be why its sparking also all of your grounds
um idk that one have you tried putting another battery in it maybe just stick the one from the donor car in just to see if it starts, i know whhen my batt fried it would parley hold a charge and wouldnt take enough jump to turn over
