Rear end gurus, inside
It's time to build up my rear end. It has to hold about 420 whp for now, hopefully up to 600-700ish in a year or two. I'll be running drag radials at the least, and will probably have slicks at one point or another. I've made up a list of parts I was going to use, I'd just like opinions. What should I add, what should I change/use a different brand, and what should I eliminate altogether. It's an 8.8 with 3.27 gears, which I'm planning on keeping.
Auburn ECTED locking diff-
http://www.4wheelerssupply.com/catal...ducts_id/71249
Hardened 31 spline axles-
http://www.latemodelrestoration.com/...0%201&comp=LRS
Trick Flow Diff cover-
Master bearing kit-
2x Axle bearing kit-
2x Gear oil-
Optional, not sure if I want to bother with these-
Pinion flange-
Differential stud kit-
Thanks guys.
Master bearing kit-
2x Gear oil-
Pinion flange-
Thanks guys.
$556 worth of stuff off LMS
$619 for the diff..
$1175 roughly... before shipping
Myself personally... I'd rather just buy everything all in one shot... Gotta love Summit!!
http://store.summitracing.com/partde...5&autoview=sku
$619 for the diff..
$619 for the diff..
$619 for the diff..
Chill, I that's not what I said. I know summit will swap parts, I was just throwing that in there because I hadn't mentioned it in the first post. Thanks for the help.
https://mustangforums.com/forum/show...t=auburn+ected
but they say it's not recommended for road racing applications or disc brakes. Any types of eliminators that are safe for hard cornering?
Thanks guys.
