Removing Dizzy Gear Help
I am trying to remove the steel gear from a stock 88 5.0 dizzy. I bought a complete motor that came with a MSD Dizzy, box and coil. From what I can find the dizzy has a iron gear.
Can I just take the one off my old dizzy and put it on the MSD? I have removed the pin from the gear on the old dizzy. Just can't figure out how it comes off from there.
You have to hold the gear in a vise or set it on top of the vise with the dizzy upsidedown so the gear will slid off the bottom, pound the dizzy shaft out of the gear with a rubber mallet or a peice of wood and a hammer. It shouldn't be too hard.
Make sure both are the same OD first, to remove it without causing any possible damage to the gear, you need a puller to remove them after driving the lock pins out. I always use a P/S pulley puller, and has worked fine.
musnicki
09-23-2015 07:11 AM
