Emissions ...HELP!
i can smell it in the drivers seat...is that leaking all over the place?...its not a fast leak but it was wet all around the lip on the corner of the tank
so heres the deal...i just bought it last week...the bill of sale says it will pass emissions ..so i can take it back for a refund..the guy i bought it from refuses to fix it at any cost ...but he will refund me my money...i only paid $2000 for it ..heres a vague pic ...
http://denver.craigslist.org/car/773831595.html
...needs paint
its low nada is $4300
...i already have about $150 into it
so i can return it and get my $2000butnot be able to buy another mustang for that price
or throw more money at it trying to get it to pass because i have 30 days to take it back
...what should i do?
...needs paint
pony up and fix it!!! it's a used care irregardless of what private owner said it doesn't matter, just take it to a shop and have them repair it, if you think that your not gonna have to dump more money into it over the long run you got another thing coming, any mustang will eventually turn into a money pit trust me!!
i dont have a problem putting some money into it from time to time ...this is my third mustang ....so i am used to that .....but you mentioned earlier that it could be a sign of a worn motor ...that bothers me .....so i'm not sure if i should put money into this car if i might return it
what do you think?
what do you think?
with how it just barely failed I wouldn't got that far just yet, take it in and have a shop diagnosis it quick before alot of time passes andd have a compression test done and a cylinder leakage test performed which will tell you the internal integrity of the motor
depends on what is wrong ...when we troubleshoot a car for an issue it is strickly time and charges and most problems can be found in an hour or two and rate will vary on the shop, you need to take it to someone who knows what they are doing and can monitor tailpipe emissions so once repair is made they can verify the problem is corrected or at the very least an improvement is seen
