Tfs stage 1 cam centerline
New motor runs like crap. Ignition is set at 10 degrees btdc with spout removed. Fuel pressure is set at 40 psi . Think it may be the cam timing which i retarded 4 degree's to get 108 centerline. Any ideas
To get it to start you have to pump the gas[ it is fuel injection]. Then once it is running it sputters on bottom end . Once you rev it up above like 3500 rpm it seems to clear a little . It wont stay running unless you keep up to 1500 rpms. I wanted to see if anybody else out there is running this cam and did they run it straight up or what.
Assuming your results from the cam degreeing were correct (didn't get the @.050" intake tappet open/close events, right?).... the other question comes to mind, did you check for the correct PR length, lifters preload? BTW.... "putting it back to 0" would mean to have the Stg 1 with a +8° advance.
So did I...... based on the Stg 1 specs the "theoretical "0"" would be to retard the cam an additional 4°..... or ICL = ECL = LSA = 112°, the Stg 1 though, should have a 4° advance in its grind........ 108° = ICL, 116° = ECL.... which would be the grind # spec for that cam.
I run a TFS1 "straight-up" and don't have any issues except for a warm start-up bouncing idle which I think is caused by my 76mm C&L.
I run 2.02/1.60 aluminum heads/TFS1 cam/30# injectors/gt-40 tubular intake.
Idles @ 750-800 rpm just fine. Screams right up to the factory rev limiter. Bucks only if I try driving in first gear under 1300 rpm.
jwog666
12-27-2021 08:09 PM
junior04
09-28-2015 10:53 AM
09-25-2015 09:06 AM
