Injectors big enough??
Old 05-16-2005, 04:32 AM
redmustang83596
redmustang83596's Avatar
Default RE: Injectors big enough??
dont know off of the top of my head, ill look it up, but as far as the spray goes, its getting put in for me... im not going to mess with that for the exact reason that you just stated--> dead motors. Bad timing and lean running motors will be shot so im getting everything done for me.
redmustang83596 is offline
Old 05-16-2005, 04:39 AM
Quik
Quik's Avatar
so bought not built!!!!!!!!!! youll get more respect out of working on your own car then having it shipped out. also more sense of pride....now if stock head bolts and size that motor wasnt sprayed and SC.. whats the CR on it?
Quik is offline
Old 05-16-2005, 09:08 AM
92EmeraldCoupe
92EmeraldCoupe's Avatar
your gonna be spraying that much I would go with 36lbs injectors to play it safe as always. you will alwats have more fuel to play with, Id also check into getting a 255 in tank pump to replace the 190 if your gonna be spraying that hard
92EmeraldCoupe is offline
Old 05-16-2005, 01:54 PM
redmustang83596
The head bolts are not stock, and i have done a lot of work on it. When i got it, it was mostly stripped of performance and i had to replace a lot of stuff, so i am building it a little at a time.
GimpyHSHS
19
12-19-2023 01:12 PM
4cylinderplus2
10-09-2020 07:45 PM
Dathan
10-05-2015 05:52 AM
UrS4
09-30-2015 10:13 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: Injectors big enough??
