1st Stang and have some tech questions
Old 09-02-2008, 09:01 PM
pidisc
Default 1st Stang and have some tech questions
Hi! I am brand new to the Mustang arena. I just got a 92 GT 5.0 with 164k and manual transmission. So far I have changed the wires, plugs, distributor, rotary button, oil, filter, fuel filter and the TP sensor. I would like to supplement my car with a few upgrades (bolt-ons). From what I can tell, it is completely stock. I am looking at new headers, exhaust, cold air intake, under pulleys, maybe a new intake, throttle body, fuel injectors and 3.55 0r 3.73 gears. Any other suggestions would be greatly appreciated!
I have read some of the upgrades and seen those from the Bad Boys Sections and it seems it is personal preference. Do the vendors posted offer any type of Military discount?
Upon starting the car and while idling, the RPM drops about 400 and the battery will discharge at the same time. I replaced the TP sensor, but all I did was take one off and put another one on. Any suggestions?
What type of battery should I use? (Optima?)
Thanks in advance for any help. Billy
pidisc is offline
Old 09-02-2008, 09:10 PM
1988TTOP
alot of ppll have trouble with under drives on the alt i use a optima and it works fine i dont know of any place that give a miltary discount
1988TTOP is offline
Old 09-03-2008, 05:06 PM
tucstang85
i have und drive pulleys and i have no problems running them ...i also ditched my ac and powersteering and now run a smaller belt (of course) cold air intake is a must if i may say so my self ..... it all dpeneds on which route your taking with your newly aquired love lol
tucstang85 is offline
Old 09-03-2008, 05:08 PM
tucstang85
oh and have fun man good luck
<a href="http://s169.photobucket.com/albums/u208/peil_520/?action=view&current=w.jpg" target="_blank"><img src="http://i169.photobucket.com/albums/u208/peil_520/w.jpg" border="0" alt="Photobucket"></a>
Old 09-03-2008, 05:12 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
400 rpm's is not enough rpm to spin the alt fast enough to generate enough current to adequately supply all systems, your problem is not with charging!!! it is related to low idle and when changing a tps it is not just a bolt on and go you need a dvom to set it to .7 to 1.0 v max and then you'll need to perform a base idle relearn.
mjr46 is offline
Old 09-03-2008, 08:32 PM
pidisc
Thanks...optima is the way I will go!
pidisc is offline
Old 09-03-2008, 08:33 PM
pidisc
good to go. Thanks for the input. I plan on using the underdrive pulley. However, I am keeping the ac!
pidisc is offline
Old 09-03-2008, 08:37 PM
pidisc
[QUOTE=mjr46;5411115]400 rpm's is not enough rpm to spin the alt fast enough to generate enough current to adequately supply all systems, your problem is not with charging!!! it is related to low idle and when changing a tps it is not just a bolt on and go you need a dvom to set it to .7 to 1.0 v max and then you'll need to perform a base idle relearn.[/QUOT
Ok I will have to google DVOM as well as a base idle relearn (lol) anyways, I apprecite the help. Thanks alot. Billy
pidisc is offline
Old 09-03-2008, 09:19 PM
mjr46
mjr46's Avatar
DVOM IS an acyronym for digital volt ohmeter no need to google it , you need to purchase one!
mjr46 is offline
Old 09-04-2008, 07:35 PM
pidisc
I actually have a automotive fluke that I can conduct the test. The idle relearn is what I am not sure about. Thanks!!
pidisc is offline
Roxon68
The New S550 2015-2020 Mustang
17
03-17-2016 08:13 PM
Pyrate Dave
09-10-2015 07:30 PM
uedlose
09-10-2015 03:30 PM
96stang3.8
09-10-2015 06:42 AM
v8sn95
09-07-2015 10:17 AM
Quick Reply: 1st Stang and have some tech questions
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
