tierod is soaked with power steering fluid??
Good luck with that half shaft joint, its gonna be a biatch: (
My suggestion, PB Blaster and Torch. I heated mine cherry red, then took that bolt out, redid the threads and installed a new bolt.
The rest is simple : ), use polyurethane rack bushings, and if lowered, offset rack bushings.
If you dont have them, now is a good time for camber, caster plates.
