odd spark plug color
Old 09-03-2008, 08:57 PM
mattwright101
Default odd spark plug color
so i pulled my plugs this afternoon to check and see how they were doing
they were all a maroonish color..
anyone have any idea wtf that means?
mattwright101 is offline
Old 09-03-2008, 09:07 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
have you been using a fuel additive such as octane booster?? or leaded race gas??
mjr46 is offline
Old 09-03-2008, 09:11 PM
mattwright101
no
just 91 octane fuel
Old 09-03-2008, 09:13 PM
mjr46
mjr46's Avatar
sometimes it can be a result of additives that are in the fuel
mjr46 is offline
Old 09-03-2008, 09:18 PM
mattwright101
well i ran some octane booster a while back but it was before i put the new plugs in
Old 09-03-2008, 09:21 PM
mjr46
mjr46's Avatar
I wouldn't be to concerned with it as I stated , most likely additives in the fuel
mjr46 is offline
Old 09-03-2008, 09:24 PM
mattwright101
well
the only reason i asked is cause its been cutting out lately
i just put in some redone 24# injectors and a MAF
it ran fine for a week or so and now its cutting out
Old 09-03-2008, 09:34 PM
67mustang302
A light reddish or dusky reddish tinge is common with modern unleaded pump fuel, due to the additives. Posting pics helps, but I can tell you in all likelihood they're fine. Mine are the same way, and I read my plugs with a scope to tune my car.
The things you do NOT want to see in a plug are black soot/ash deposits covering everything, chipped/cracked insulators, glazed over looking insulators, or a burnt look from excessive heating, black peppering(comes from mild detonation that you won't hear or feel) or silver peppering(bits of melted aluminum from the pistons due to detonation that you may hear and feel), signs of physical damage, or heavy melting/erosion.
You can also tell heat range and ignition timing by the threads and ground strap respectively. WOT fuel marking should be a light brown or grey "fuel ring" at the very base of the insulator where it meets the plug body, down where you really need a scope to see. 3/4 to 7/8 of the way around is typically the "lean best power" marking for the tune, but some engines may make more power with a full turn of fuel ring, or it may be needed to avoid detonation.
67mustang302 is offline
HRnB
Off Topic
126
11-13-2017 12:36 PM
Dathan
10-05-2015 05:52 AM
BOB ROME
09-28-2015 11:10 AM
popsotto
09-28-2015 06:58 AM
Quick Reply: odd spark plug color
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
