c&l mass air meter, good or bad?
I am going to need to upgrade to larger injectors and wanted to see if anyone was running a C&L mass air meter. From what I under stand you can use your stock mass air meter and just get different sample tubes for different size injectors, is this true? How well does it work? Good or bad performance?
I've always heard to stay away from C&L, apparently they use a sub-standard system for their MAFs.
lots of people dont like c&l ive never used them personnally. you dont use the stock meter and change tubes, you by the c&l meter and if laster on down the road you change injector size for whatever reason (usualy more power) then you can change the sample tube on the c&l meter
