93 4cyl to 5.0 - final list
Hey guys... im just looking for answers here since I lost all of my bookmarked sites and threads about this topic and cant find the one i was looking for in the search.
I have a 93 2.3, and i will be leaving for college in two weeks and i am planning on giving my mustang to a body shop to get touched up and a mechanic to drop a 5.0 in there, all on barter money from the family buisness. We have 40k in barter money, and nothign to spend it on, so I will be getting all work done at 50% cost.
Im trying to put together a list of things I will need and problems that will arise so I can warn the shop that will be doing the swap to make it as easy as possible. There is a junkyard on barter as well, so I can get the engine and all the parts i need for no cash either.
What I have done to the car is, 5 lug conversion with 96gt spindles up front and two ranger axels out back with drums. Still 7.5 rear end
I will need:
The engine, 302 from 1992 or earlier for forged internals
a Wiring harness from a 93 mustang, and only a 93 mustang
Fuel lines
8.8 rear end
New speedo/tach
Exhaust
what else do i need? I know theres more.. i cant remember.
Also, mines an auto.. I would like to make it a manual, how hard is that conversion?
Thanks it advance guys!
I will need:
Fuel lines
8.8 rear end
New speedo/tach
Exhaust
Pretty sure i dont need the crossmember cause 93's came with the double hump crossmember...
notches are hard to find where i live, and iv put to much work into this car to just sell it and buy a 5.0 when i can do the swap for virtually nothing.
and maybe in the future i would like to boost it, so if i can find one from a 92 or earlier, ill use that. if not i guess ill settle for a 93
^^ yeah got that on my list. heres my list so far
motor mounts
crossmember
drive shaft
transmission
complete engine (with everything on it)
MAF or SD
computer (or carb)
if 5 speed then all the cables and clutch stuff, also pedals
if auto, then just whats listed above.
exhaust
you'll have to move the axle brake line if doing duals al the way back
bigger brakes (so they don't warp)
motor mounts
crossmember
drive shaft
transmission
MAF or SD
computer (or carb)
exhaust
so your finally doin the swap about time. if your lookin for a shop to do this bring it on down to where i work at billys auto well do it for you no problem. im doin the same thing with my car. i just bought a 93 thunderbird with the 5.0 ho motor for like 400 bucks so im gonna swap it into my car.
mungodrums
09-28-2015 10:54 PM
