JEGS cylinder heads
JEGS cylinder heads
i was wondering if these would be any good? heres the stuff off the page:
JEGS SB-Ford Aluminum Heads
Product images may differ from actual product appearance.
Bolt-On Horsepower!
Bolt on horsepower with these 18° high flow 170cc intake runner head vs. the wimpy 124cc stock heads. Cast from virgin A356 aluminum, heat treated and CNC machine finished to very strict tolerances. Drilled and tapped for accessories. Non-EGR design.
Other features:
58cc CNC machined combustion chambers
CNC matched intake and exhaust ports
1.440'' springs, 130lbs seat pressure - for hydraulic roller camshafts up to .580'' lift
2.02'' intake and 1.60'' exhaust valves
7/16'' rocker studs and 5/16'' guide plates included
Works with stock piston valve notches with up to .550'' lift cams
Stock location exhaust and intake ports
Non-Emission design
Designed for 302 blocks. Will not fit 351W with 1/2'' head bolts
For best performance results use 249-35-518-8 Camshaft (May need to notch pistons).
Bolt-On Horsepower!
Other features:
Non-Emission design
I have a set of 195 Canfields... I have NO IDEA if they are the supplier for Jegs or not.
I'm doubtful at first glance, but I will ask this guy I know...
If you want Canfields, there may be a better place to get them.
Jeg's will give tech advice like this...
"For best performance results use 249-35-518-8 Camshaft (May need to notch pistons)."
lol
lol
