ok guy i need help bad!!!!
ok well had to oreder one from the internet, dang autozone guy said i would have to buy a new pressure tester just for the $2.50 adapter. hahabut im going to get another tps and iac tomarrow from a user donor car
yeah i am , im just going to grab some spare parts just in case, im going to test the tps and then then other tps im getting cause i really dont like the way the one in the car looks, meaning the scraps and wear it has. ALso is ther any way i can test the iac
ok well since this dang hurricanes hear i cant do anything!!! but yesturday i went out and started the car to let the batt charge up. i primed the pump slveral times before starting and it cranked up and idle low a few times back up and then down then leveled off and ran ok. but heres something i havnt had, when i would give it gas(at the throttle body) it sputters its way up, then being at like 2K rpms go to give it a good bump and it sputtered pretty good so i gave it alittle more gas and i was getting a backfire or pop sound through the intake. i check the timing its at 14* runnning super unleaded. And after i let it warm up and took it down the road it seemed like it runs better warmed up. COuld an injector be cause this, i say this cause the injectors were from the motor that came with the car, they were new but the car sat for like 3 years and was hardly started
it sounds like maybe you have a misfire, I'd double check the firing order(13726548) counterclockwise and make sure cap rotor and wires are good and well as all pushed on the terminals and plugs good
ok ill check, the cap, rotor and plugs are all new, im probly going to go ahead and order some ford racing wires. also could the tfi module cause this also, i have two spare dizzys if i have to change it. also when you put the spout connector in, is it suppose to move the timing at idle cause im getting like a 10* constant movement at idle, and when i rev it goes and stays at almost 40*.
