blown gasket, leaky/burnt valve , low compression due to rings not sealing, in short alot of things, the hardest thing to do for me is feel how bad or what your feeling is...if I could put my hands on the car in less than an hour most likely the problem could be narrowed down using proper test equipment
LOL dang, ok well just got done with the compression test, its my first time but im sure i did it right,ok heres the numbers as follows
cyl#1- (135psi) cyl#5- (130psi)
cyl#2- (132psi) cyl#6- (131psi)
cyl#3- (132psi) cyl#7- (130psi)
cyl#4- (130psi) cyl#8- (133psi)
