wierd tranny problem(tranny just rebuilt)
Old 09-06-2008, 10:30 PM
hindelk
hindelk's Avatar
Default wierd tranny problem(tranny just rebuilt)
well i just bought a 90 ford mustang gt(auto) the kid just had the tranny rebuilt and also had a shift kit put in no more than a 100 miles ago...well id say ive ran it prolly 150 miles and no when it gets warm when i start to take off in first it revs out untill i hit like 3500rpm(moves very slowly) and grabs like i neutral droped it....the hotter it gets the worse it is...you can tell its spinnin something in the tranny but its not going anywhere fast.....and a little back info also it never really shifted "right" it would shift real quick...was in od by 35 mph....and sat at 2500rpm at 60 seemed a bit high...any inputs on this...and it was rebuilt by crt a local mustang shop
hindelk is offline
Old 09-06-2008, 11:23 PM
blownfiveo17
blownfiveo17's Avatar
i have the same problem with my 92 lx. it wont shift when its suppose to, and it shift really hard into 3rd and od when i let off the gas, but if i keep on the gas is wont shift as hard. I dont know whats wrong with it, previous owner said he had it rebuilt.
blownfiveo17 is offline
Old 09-06-2008, 11:26 PM
94StinkinLincoln
94StinkinLincoln's Avatar
check the TV cable, thats a huge problem on aod's
94StinkinLincoln is offline
Old 09-07-2008, 11:52 PM
hindelk
hindelk's Avatar
that would explain wierd shifting but the slipping action off the dig....im startin to more and more think its the torque converter seeing as it shifts fine when it finaly grabs..and the tranny has been rebuilt 4 times int he past 4 years and now its a complete street strip rebuild..and id guarantee they never cleaned or changed the converter
hindelk is offline
hindelk
hindelk's Avatar
also hes using wolfs head synthetic tranny fluid..do aod's and synthetic work well together?
hindelk is offline
Old 09-08-2008, 06:29 AM
94StinkinLincoln
the tv pressure can cause all kinds of problems, but if the converter has a bunch of miles on it, if its stock, then yea get a new one and a trans cooler.
use the merc 5 for awhile, i guess 1k miles or something and then use the synthetic fluid, im not sure right off the bat w/ the syn. is good or bad, the merc5 wont hurt it.
Old 09-08-2008, 08:58 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
you haven't mentioned if you have checked to see if the fluid level is correct/not low..have you???
mjr46 is offline
Old 09-08-2008, 10:48 PM
hindelk
hindelk's Avatar
fluid level is fine...also replacesd the tranny filter
hindelk is offline
Old 09-09-2008, 10:21 AM
aode08
aode08's Avatar
jack the car up, remove the few bolts to the torque converter inspection plate, turn the crank or bump starter, until you see the torque converter drain bolt.
Drain it, and let us know if silver metal comes out with the oil.
aode08 is offline
angeljoelv
SVT Forums
09-10-2015 09:12 PM
Pyrate Dave
09-10-2015 07:30 PM
Luke9222
09-04-2015 06:46 AM
Quick Reply: wierd tranny problem(tranny just rebuilt)
