just ordered nitto drag radials
RE: just ordered nitto drag radials
jegs says I should have the tires by 4:30 friday So I'am going to the track saturday and still need a little info
what psi should I run?? and what rpm do you think I will be able to launch at??If this pic of my launching looks good I can't wait to heat up th stickies
[IMG]local://upfiles/11405/5F4BFCEC911A4E81A499E4D385D1BA30.jpg[/IMG]
Start them out at about 20 psi and work your way down. I can dump the clutch on my car at 4000 rpm and hook but thats on a BFG which hook better than Nittos. Try 3000 rpm and if you spin go lower and if you bog go higher. Be sure to post up a time slip, I wan to see you 60' time.
hey, whats the biggest rim and tire combo i can put on my car? if i dump the quads and just run some strange shocks in back, and do NO frenderwell work/beating. thanks!
Yep, I want to know, I am going to the track tomorrow night, and I am going on BFG radials.. Should be interesting hoping for a low low 14 @ 94+ mph... Hoping for a 1.9 60ft.. pulled a 2.0 with my street tires.. I think I should be able to hit a 1.9 with the radials, and thats with stock suspension..
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
