??what is this?? intake manifold outlet
putting my car back together, found where all the other lines go, but...
in the picture, the outlets circled are what im talking about
the one to the right, is for the pvc thing that comes from the back of the lower intake (wtf is that thing called again?)
but i have no clue what the other outlet is for, ive looked alround!
any help would be great!
That would go to the PCV Valve is it were on a stock Manifold,and I still use it for the PCV Valve on my Tubular GT-40. It all depends on how you have your vacuum line run as to what function that part is/does.
That is the PCV valve, it goes to the hole on the back of the intake, and the other side goes to one of the ports on the middle part of the intake
dont leave it out if you dont want your dipstickl to shoot out and spray oil everywhere... its important
yes it is a typhoon intake manifold.
ill have to look, but i think theres only one vac line coming from the lower intake, and im 90% sure its got its home already.
the brake booster on mine is hooked to the vacuum tree.....
eh, this is the only thing im not 100% on, as soon as i get this figured out, ill have the car back together and running in about an hour after i start in the morning!
whooo-hoo!
my pvc just pop's right back out of the hole in the back of the lower intake, so ill go pick up a new one in the morning, maybe its the wrong one or something, idk.
if anyone else can chime in that would be great, otherwise ill go with fuzzydice and see if its a vac line off the lower intake manifold.
