Door Lock Actuators
Old 05-18-2005, 02:14 AM
stanging
stanging's Avatar
Default Door Lock Actuators
Does anyone know what other years of Fords door lock actuators will fit a 93' Mustang. I have looked at the local Pull-a-part yard and didn't know ford made so many of them with different shaft lengths. For the Mustang it is a short one.
stanging is offline
Old 05-18-2005, 11:27 AM
stanglx2002
stanglx2002's Avatar
Default RE: Door Lock Actuators
87-93 will all fit but no sure about any other years
stanglx2002 is offline
Old 05-18-2005, 09:17 PM
stanging
stanging's Avatar
I guess I should have made it a little clearer, what other ford cars besides Mustangs will work in the Mustangs.
stanging is offline
Old 05-18-2005, 11:35 PM
house302
house302's Avatar
just spend the money on new ones at 50resto.com because they have a kit that comes with new door panel snaps for like 80 dollars and also you will probably ruin the bracket for the lock actuator because you have to drill out a rivet hope this helps cause i just went through that with my stang
house302 is offline
Old 05-18-2005, 11:36 PM
house302
house302's Avatar
sorry that 80 dollars icludes both lock actuators
house302 is offline
Old 05-23-2005, 02:41 AM
stanging
stanging's Avatar
You don't need to drill the pop rivet out to change the motor, spray some W-40 on the rubber gromets and push it down and it will come out, but first remove the rod from the linkage. I have changed a couple of them on a Mercury Marquis.
stanging is offline
Old 05-23-2005, 09:58 AM
stanglx2002
just be careful some of those backets are plastic and they break
jerrytubes
10-23-2015 12:11 PM
breaking
10-02-2015 01:27 PM
guitarman376
09-30-2015 05:54 PM
Sixer4Life
09-29-2015 07:03 PM
09-25-2015 06:58 PM
Quick Reply: Door Lock Actuators
