trick flow typhoon or Edelbrock intake
whick upper and lower intake should i get. i got 30 pound injectors 6psi blower stock heads crane cam rocker arms 1.7. i was thinking about the Trick Flow EFI Street Burner, Edelbrock Performer, or the Mustang Typhoon. which is the best performance intake and which is best for my setup. also what size throttle body do i have to get to go along with everything. please help
RPM II. dont look at the typhoon unless you feel like doing some clean up/port work on it....then shes worth it.
i wouldnt go with the TF intake with that blows.
BTW did anyone read the summit built sn95 on 5.0 magazine september issue? 347 stroker w/ trick flow top end only hittin 311hp and 345tq!
I usually tell people to buy the Systemax intake, and others have argued about the RPM II. I actually looked at the RPM II the other day and started laughing. It's almost a dead nuts rip off of the Holley. LOL!
So I guess the answer is...Don't bother with the intakes you listed, get either the Systemax, or the RPM II.
are systemaxx available for 351w's??? are they good only if your trying to make serious power??? whater happend to the vortech intake manifold? they are really hard to find. is the systemaxx 2 more efficient if i bought the kit with heads cam and intake>>>??? thanks
For a 351 looking in to Trick Flow R series intakes.
http://www.trickflow.com/egnsearch.a...=KeywordSearch
