suspension help
suspension help
Im planning on building a road race car. The base is a 1994 v6 completely gutted. Putting carburated, supercharged 302, probably 400-450hp, 8.8" rearend, i need some opinions on a good front and rear suspension setups. Price is not a big issue at this point. I need a suspension that can handle the extra weight of the 302 and the extra power. any opinions are welcome. Thanks
RE: suspension help
if you want a really good road race car then go to maximummotorsports.com and they sell a complete kit. Here's the kit you will want and the parts you will need for a road race car.
The Maximum Grip Box
MM Strut Tower Brace*
MM K-Member
MM Front Control Arms w/ urethane bushings
MM Front Coil-Over Conversion Kit
MM Adjustable Tie-Rod Ends
MM Standard Torque-arm
MM K-Member Brace
Solid steering shaft
MM Full Length Subframe Connectors
MM Aluminum rack bushings
MM Panhard Bar with Aluminum rod
MM Adjustable Rear Swaybar
MM Caster/Camber Plates*
MM Rear Lower Control Arms without spring perch or swaybar mount
Hypercoil Coil-Over Springs
MM Rear Coil-Over Conversion Kit
Bilstein Sport struts & shocks
Urethane swaybar bushings
Urethane swaybar endlinks
MM K-Member
MM K-Member Brace
RE: suspension help
Read this book. Its only 12$ from amazon.com
Mustang Performance Handbook 2: Chassis and Suspension Modifications for Street, Drag and Road Racing Use. Includes Suspension Geometry, Chassis Setup, Brakes, Tires and Wheels, test
RE: suspension help
Sorry here is a link
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Alot of road racers I know say this is the bible for mustang road racing. Im not sure how much time is spent on the 94+ cars. But for 12 bucks it might help some. I have only flipped through it but I ordered one the other day. There might also be a good sn95 book out there but I have not looked.
Matt's 95 Stang
10-05-2015 07:16 AM
