Gears help!
Gears help!
So ive been debating for awhile now about getting 3:73 or 4:10, ive been leaning more towards the 4:10 but wont it be hard to get the tires to hook up off the line? Whether I go with either gear set my speedo and other things will be messed up, i have seen a recalibrator for sale but it is about 90$, is that worth it, or should i just try to do it manually and get it as close as possible?
RE: Gears help!
ORIGINAL: JontheBaptist
RE: Gears help!
People who say you can't get 4.10's to hook are either too lazy to set up the suspension the right way or don't have enough experience with cars to know better. Yes 4.10's are harder to hook if EVERTHING else is left stock but guess what? So are 3.73's. Get some sticky tires and control arms and the car will hook just fine.
RE: Gears help!
ORIGINAL: JD1969
Yeah but the 4.10's are HARDER to hook. But he didnt say you CANT get hem to hook. And sticky tires on the street? Cant be a safe daily driven car then.
Get the 3.73's. Thats enough for a street car.
RE: Gears help!
yeah if this is ur daily driver then go 3.73 if u go 4.10 you'll just be "drinking it" even though acceleration will be better...wat it comes down to is if u like spending all ur money at the gas pump or not...but either one ur mileage will go down it all depends on how you drive it!!
RE: Gears help!
Don't know what you have for a motor...but my opinion is that 4.10"s are to low unless you have a big cam and can take use of the upper rpm range to compliment the gears. If you're stock, you'll quickly get into the upper rpm range where a stock motor starts to weaken and you'll have a tendency to be reving outside of your powerband...just my opinion.
RE: Gears help!
ORIGINAL: tomabram
ORIGINAL: JD1969
