What is this shock behind my rear tire?
Old 09-24-2008, 06:52 PM
jzandy
jzandy's Avatar
Default What is this shock behind my rear tire?
i am trying to get wider tires in the rear but i was told the biggest i could go is 245's due to the clearance issue with this shock. what is this? what is its purpose? can it be taken off? does something need to be put back on in another location? i see others with 275's and 295's so i know there is a way.
jzandy is offline
Old 09-24-2008, 07:00 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
It's called a quad shock and it helps prevent wheel hop. You can flip it for added clearance.
PRO50SC is offline
Old 09-24-2008, 09:01 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
255's will fit on 16 inch ponys with minimal tail pipe rub on cornering
mjr46 is offline
Old 09-24-2008, 09:50 PM
92stangerang
92stangerang's Avatar
do you have your exhaust running all the way out? i have 295s. i had to beat the inner part of the fender well to stop rubbing. took 10 mins on both sides. (5.5 backspacing) . before that i had 265s without any rubbing. but its was a 4 banger origianly so i only have dual shocks.
92stangerang is offline
mmarsh3014
Wheels & Tires
10-20-2015 09:08 AM
musnicki
09-23-2015 07:11 AM
2007CalSpec
09-09-2015 05:37 PM
M3hunter
09-05-2015 03:42 PM
Luke9222
09-04-2015 06:46 AM
Quick Reply: What is this shock behind my rear tire?
