overheating... help
well, in any case im going to swap the CCRM from my 94 GT which i KNOW works into my 95 cobra. Would that be compatible??
i know how the mechanical and electrical fans works, thats why i said run a hot wire cause a mechanical fans going to start spining when you first start the car, and he said he turned the a/c on to see if the fan comes on, and elctrical fan is suppose to always come on when the a/c is turned on, cold or hot
yeah i know where it is.... also the AC clutch is BARELY operating, and i was having a slight problem getting it to fire up (fuel pump?).... doesnt the CCRM control that, too?
If your AC clutch isn't workign correctly then the test with turning on the AC to verify the high speed fan is coming on wont' work.
The function that activates the relay on the CCRM when the AC is turned on is a pressure switch in the AC system. so no pressure = no fan when Max AC is turned on.
http://www.mustang-tech.org/wiki/Image:CCRM-AC.gif
Here is the wiring diagram I used when trying to figure out if my system was not working correctly.
Sombody please correct me if I'm wrong because i'm not 100% sure.
