Trick Flow top end kit problems
Old 09-28-2008, 07:38 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
SD tuner or MAF conversion = only two options for proper fix!!
mjr46 is offline
Old 09-29-2008, 04:51 AM
dennisdiecast
dennisdiecast's Avatar
also by converting to MAF, would this fix the problem of steping on the gas and not having the instantaneous power (there is an rpm lag)?
dennisdiecast is offline
Old 09-29-2008, 06:32 AM
Joel5.0
Joel5.0's Avatar
If done right.....sure. You have an upgrade that is not compatible with your current EEC system, that's the correction you need to concentrate on.
Joel5.0 is offline
djbigskrilla
09-20-2022 01:04 AM
mstahoo
SVT Forums
08-19-2021 09:15 PM
Gun Jam
10-04-2015 12:10 AM
Choppertwo
3.7L V6 Technical Discussions
08-18-2015 02:21 PM
Bryan@Autogeek
08-05-2015 12:33 PM
Quick Reply: Trick Flow top end kit problems
