Wiring Harness
Wiring Harness
does anyone know if a 1984 v8 hatchback wiring harness is the same for a/c and non a/c wiring if you were to simply change the heater box, install a a/c comppresor, ac lines, and brackets, my question would the wiring be there. or not
you'd need the switch panel and it often times is just a plug and play. look for the wire harness end out under the hood for the a/c compressor clutch, it may be taped back on to the harness or something
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
breaking
10-02-2015 01:27 PM
