cutting out
cutting out
so when i go WOT my car cuts out and my tach goes erratic. but sometimes when im crusing it ends up doing the same when im going at freeway speeds. when i gas it at about 3/4 of the way it accelerates fine. just wondering if you guys could gimmie some input.
Do you have an aftermarket tach? If you do then unhook it from the coil and try that. If you don't then I'd replace the coil. It's obvious that your having problems with the coil because the tach is going haywire. A bad aftermarket tach can cause the problem.
jwog666
12-27-2021 08:09 PM
