tranny sawap
depends on if you get them used or all new, of course the clutch pedals will be used and you'll need the clutch cable, t-5 tranny, bellhousing, flywheel, clutch and clutch fork, shifter and t-5 crossmember and there may be something I'm leaving out, check out ebay for a package deal
I got all my stuff used, even the clutch and it all cost me, at the time 150.00 for the tranny, crossmember new = 60.00 , cable, 35.00, clutch pedals, 25.00, clutch 15.00, flywheel 10.00...so I got all my set up for under 350.00, so you should be able to purchase it all for under 500.00 if you shop smart
you dont need a new cross member. all you need to do is grind the welds and slide it on the tubes. very easy. I have a spare pedal support. pm me if intrested. You can do this swap for anywhere from free to 2k. just depends if you can find parts. the last one i did cost my 500.
treesloth
09-28-2015 07:03 AM
jaiidutch
09-14-2015 10:29 AM
