boggin down at WOT
boggin down at WOT
Last month I did heads and cam on my car and got it to run real good, this last weekend i put 24's , a new MAF and a edlebrock intake manifold on the car, Now the cars bogs down and backfires when i mash on it. I never touched the distributor so i dont think its the timing. I thought it was a vaccum leak so i hooked up a vaccum gauge, it reads about 7 or 8 which is really low but i know the cam lowers it just dont know ho much. I can sneak up to high RPM's at quater to half but at wide open shes says no. Thanxs
it runs perfect at quarter and even up to half throttle
the cam is a stage one trick flow
RE: boggin down at WOT
what mass air meter are you using?
if it has the sample tubes make sure the small side faces the filter.
when I got mine it already had the tube attached and they put it in backwards, so my car ran, but like crap.
really rich, and popping, bogging, and it just lacked power.
changed it around and it ran strong as ever.
ORIGINAL: rustynotch
when when u say small do u mean in diameter or lenght, the short lager diameter is facing the filter and the smaller longer side to the throttle body
make the smaller diameter face the filter. you will notice a crazy difference.
I had the same problem when I first got my maf.
