82 with 87-89 wiring fuel gauge problems
just bought a 82 stang, real clean platform to start with, the PO put in a 87-89 dash and tryed to wire it himself, nothing worked when i got it, i got the oil pressure/temp/volt gauges working, and im trying to get the fuel gauge to work...i THINK the car still has the 82carb sending unit in the tank...will this work? and if i need to replace the cluster can i use any 87-93? 4cyl or 8cyl??
As far as differences between the 1987 - 93 cluster check out the link below on my web site it should answer any questions about them for you. The only difference you will find with the 4 vs. 8 will be the tach and in later years the speedometer.
Differances in 1987 - 89 & 1990 - 93 Instrument Clusters
Hope this helps.
