need help replacing pistons?!?
ok so i bought a 306 short block from a friend but number 4 piston is bad. no damage to cylinder walls. im looking to buy a new set of pistons and rings and bearings. im looking to do it myself but it would be my first time. does it just come down to poping the pistons out and putting new ones on the rods and sliding them back in? or does it involve more then that i just dont want to screw it up. any info or advice would be greatt
i just took the rest of the pistons and crank out and some of the rod and main bearing were like copper looking. those have to be bad bearings. is there sumthing that would cause that or is that just normal wear?
Sort of.
Pistons are attached to the rods with a pin. The pin is either press fit, or floating. It's easy to tell the differance. Move the rod back and forth. If the pin moves with the rod, it's a press fit. You need a shop press to change them.
Before adding new rings, you need to refinish the cylinder walls. You need a simple cylinder hone, run slowly with a drill motor. It's not difficult, just pay attention to the pattern you're leaving behind.
When installing the new pistons, make sure the ring gaps are in the right place, and the piston is oriented in the right direction. There is a "front".
honestly the cylinder and piston need to be measured and specs compared to one another, meaning cylinder should be checked for out of round and taper and then measure piston to make sure there will be no inconsistencies that'll cause the piston to rock or sieze in the bore while it is running, also cylinder if found to be in spec should be honed
acculy you might need the crank ground as well if any of the bearings or surfaces were scratched up, simplest thing to do, strip the block, take the block, crank, and pistions/rods in and have them check it all. simple and done. not sure if you know how to mike a cylinder or check any of it and yea, just take it all in.
