A lot of heat
A lot of heat
I have have 1991 Mustang GT 5.0 5 speed.. I've noticed when I'm at freeway speeds for a while that there is alot of heat coming from the center console (the whole area above the gear box)... If I have a candy bar or something in that area it'll melt the chocolate... I was just wondering if that's a problem... Thanks
Lee
Lee
i have that same problem in my 94..only when the ashtray doors open i can feel it...if its closed it stays trapped. my guess is its just the exhaust heat coming thru the hole that the shifter goes through. even tho the rubber boot is supposed to seal it..the heat still makes it through
Here's the scoop"
"The average light off temperature at which the catalytic converter begins to function ranges from 400 to 600 degrees F. The normal operating temperature can range up to 1,200 to 1,600 degrees F. But as the amount of pollutants in the exhaust go up, so does the converter's operating temperature. If the temperature gets up around 2,000 degrees F or higher, several things happen. The aluminum oxide honeycomb begins to degrade and weaken. The platinum and palladium coating on the honeycomb also starts to melt and sink into the ceramic substrate reducing its effect on the exhaust. This accelerates the aging process and causes the converter to lose efficiency."
