alternator relocation?
I have a 5.0 in a '90 RX-7. The alternator is both in the way of the upper rad hose, and the hood.
Is there a simple way to relocate it to the lower-left, rather than the upper left location?
Ok, apparently the front cover and accessory brackets from an SN95 motor (I'm unfamiliar with the terms, not sure what model/year that is) should lower teh alt and a/c brackets, and move the water pump away from the radiator. Can anyone confirm this? If so, what model/year should I be looking for to get these parts? Is the front cover that difficult to change?
the sn95 refers to the 94-95 models as opposed to the fox platform which runs from 79-93. i dont know about the alt being any lower but in the sn95 the ac and p. steering are reversed. fox ac on top, sn p. s. on top
i dont know hopw to post up websites or stuff like that, but id try summit or Jegs and search for alternators brackets and tensioners. i hope that helps. even if its not specifically for our fox body mustangs, it will work. it should be a universal tool.
