rough idle !why?
rough idle !why?
I got a 1990 mustang gt and idles badly the all engine shakes and my check engine is on I check the codes and I get this 34,63,85 with the engine off and with engine running , 98 ,63 but it seems to run ok exept when Idles and smells like exhaust please help !
do you have a way to decode that? if not if there is an autozone around they will do it free could be a large vaccume leak, plug or wire bad, o2 sensore if equiped, if it has always done it since you got it it could be a cam (highly doubtful)
you have a misfire, that's why it has a rough idle, vaccum leaks will cause a rough idle, also defective ignition components such as a bad cap, rotor, wires or plugs will do such..has it had a tune up recently??
perform a compression check and make sure all cylinders are good, or with a insolated pair of pliers pull the wires one by one on the cap noting which one does not affect load change when pulled, the one that does not affect load change when pulled will be the prob cylinder, or run a koer/cylinder powerbalance test using the ecm function to see which cylinder is not contributing power
