Climate control only blows out defrost vent
Old 10-12-2008, 10:12 AM
thajuggla
thajuggla's Avatar
Default Climate control only blows out defrost vent
hey guys, 87 5.0 gt. No matter what the vent setting is, it blows out the defrost. I am looking for a picture of the vaccum lines, or atleast a short instructions on what to check and do to fix this, any help is appreciated. thanks!
thajuggla is offline
Old 10-12-2008, 01:56 PM
thajuggla
thajuggla's Avatar
bumparooni
Old 10-12-2008, 02:33 PM
RUDEDOG.357
RUDEDOG.357's Avatar
Dont have a shop manual at home but I would ck for vacuum leaks under the hood. Then ck the vac hose that goes through the firewall into the dash. should be on pass side by the heater hoses. hope this helps. The climate control is set up to default to defrost.
RUDEDOG.357 is offline
Old 10-12-2008, 02:45 PM
thajuggla
thajuggla's Avatar
should i also remove the climate control panel and check the hook ups on that or will there be nothing there that has anything to do with it?
Old 10-12-2008, 03:16 PM
RUDEDOG.357
If you pull the glove box down you may be able to see the line or hear if its leaking. If you dont see a broken line then I would pull the control panel.
Old 10-12-2008, 03:42 PM
thajuggla
thajuggla's Avatar
Ok I pulled the glove box and I see a rubber piece that has lines going into both sides. There are 4 of them on each side, one that has blue stripe, red stripe, white stripe and one thats straight black. There are about 5 other holes on both sides that these can go into, are there specific holes they have to go into? Also, Im guessing that certain colors have to match up to the opposite side am I correct?
Old 10-12-2008, 03:45 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
check out under the hood of the car = little small black vaccum line going into the firewall= source vaccum for climate control, trace it for a broken line
mjr46 is offline
Old 10-12-2008, 03:59 PM
thajuggla
thajuggla's Avatar
ok the line under the hood seems fine, no leaks at all. from between the inside of the firewall to the climate control panel, where is this line located as im guessing thats where it is broken in between there.
Old 10-12-2008, 04:02 PM
mjr46
mjr46's Avatar
it enters the firewall close to the evaporator
mjr46 is offline
Old 10-12-2008, 04:28 PM
thajuggla
thajuggla's Avatar
ok mjr46, you rule! I got it fixed now, seems the lil black line wasnt exactly connected 100%. now i have another question...
When I turn the AC on, I dont hear the a/c clutch kick on or off. What could be the problem with that?
Quick Reply: Climate control only blows out defrost vent
