Soft Brake Pedal
Soft Brake Pedal
just did the 5 lug swap and other stuff blah blah blah and after getting everything done the brakes are very soft and the car seemes to slow just the same as it did when it had drums can anyone help me?
Some vehicles require a different Master cylinder for disc vs disc + drum or drum + drum.
Is this a dually or a car? Also, is the proportioning valve internal or external to the master cylinder? If you have a brass block that lines from MC go into before going to the rest of the vehicle then it's external. This part is typcialy different depending on the brake setup because the amount of hydraulic pressure needed to "activate" drums is much lower than that required to activate disc, thus the soft feel. The rears are not getting fully activated.
Stopping power on disc + drum is usually 80%/20% with disc+disc being 70%/30%
Last edited by Derf00; 10-13-2008 at 12:00 PM. Reason: grammar and spelling errors
