Any one with slicks?
If so what size do you run on the fox body? What modifications? i'm trying to see if these will fit
https://mustangforums.com/forum/wheels-and-tires/489658-will-these-fit-a-91-lx.html
I ran ET streets that were 26 inches tall and i think 10 inches wide and had no problems unless i took real sharp turns....I just put some of those new ET Street Radials that Mickey Thompson came out with and they are 26 in. tall but a little bit wider...and as long as i dont turn to hard iam good....but if your just drag racing....no prob.
Hi im looking to purchase a used set of Weld draglites. the fronts are 15 by 3.5 and the rears are 15 by 8 with 10 by 26 inch Hoosier slicks. the offset for the rear is 5.5 with a 25 positive offset and a hub bore of 3.18 The fronts are 15 by 3.5 with a negative offset of 13 and 1.75 back spacing and the same hub bore. My car is converted to five lug using the ranger rear axles and the Lincoln mark V rotors upfront.
Will i have any issues mounting up these rims ? If so What modifications would be necessary? Thanks for the technical help, Andrew
Edit tire up front are Tires are 25 x 4.5 x 15 Moroso DS-2’s
Any one know what a reaosnable price is?
The ones in the pics are dr's, but I run the exact same size in M/T slicks w/ no problems either
They do not rub.
Dragonus18
09-09-2015 01:21 AM
