i just dont get it
i just dont get it
Well I thought my idle problems were fixed on the 93
ive done the base idle reset, checked tps, and i got it to idle pretty good around 1000, but thats with the stop screw on the throttle body all the way loose... and thats after the base idle reset and the IAC disconnected
but after i drive it for a bit and i let it idle, it sits around 1300-1500 which i thought was really odd
its not throwing any maf codes its just throwing a code for my o2 sensor
Yep, check the codes...
IAC could be sticking? cleaning may help?
if the IAC isn't able to compensate, then idle speed will increase as the engine warms up... that is normal.
(friction/oil drag drops as the engine approaches op-temps)
Run the codes, just in case though.
jason
jason
