harmonic balancer removal help
i bought the harmonic balancer puller, removed the pulley and bolt in the middle and tried removing the balancer but its so tight. i tried forcing it and it crack one of the holes for the pulley. how can i get this off? its soaked with spray. also any tips for matching the new one?
my best guess here would be that you're using the puller the wrong way. if you managed to crack one of the pulley bolt holes, you're doing it backwards. the balancer is pressed on, but almost half my experiences, a light tap from the back with a hammer is enough to knock 'em off.
wow the washer was in there lol. i just took it out and the balancer came out like nothing... thanks stangguy306 but i just thought of another question. can i fit a cam in there without removing the front end?
small blower, typhoon upper and lower, 70 shot, 30 injectors, and other small stuff. i will be making 400-450 after tune but i want the biggest cam for my setup without having to update injectors. this will be my first cam swap
