what does it take to make a fox stang hook?
first-3rd gear im smoking my tires(255/50/16r). chek out my sig to see my suspension mods.dont have aftermarket springs.
I would start w/ some control arms and some sticky tires. Hell, I would start w/ sticky tires and see where that gets you.
+1....but are your tires on there right now old/worn or? You shouldnt spin that bad...
lowers, sticky tires, and 50/50's will give you 1.6 sixties all day long.... and the ability to lift the tires over 6" if you had 4.10 gears
but you don't.... the 3.08's are hurting you bad, you need more throttle to move you, but more throttle gives more tire spin. contrary to popular belief... low launch on 4.10's and feathering will yield better sixties than stock or 3.55 even on street tires but like said b4....... a sticky tire goes a looooooooooooooooooong way |
some 275 / 50 / 15 mt et street radials and then you'll hook fine:D
thats a bad a$$ tire...the MT's are nice.
contrary to popular belief... low launch on 4.10's and feathering will yield better sixties than stock or 3.55 even on street tires well said if you could only get most people to believe this. also when the 3.08s get spinning it is very hard to get them to recover due to the tire speed that you are seeing. and if they do recover you get this thing called bog. |
some nice control arms maybe even lift bars for the lowers. shocks springs and sticky tires and +1 for mt et streets. o and once you get the control arms you can throw away your quad shocks.
M/T's will help a bunch.
My BFG G-force drag radials put a stop to my tire spin real quick.
