Tranny swap from 92 to 93
Hi Guys,
I am probably going to buy a 92 ford mustang coupe with a manual 5 speed tranny with only 66k miles on it. I already have a 1993 5.0 convertible automatic. What I want to do is swap the manual into the convertible and swap the Auto into the coupe. How difficult would that be? Would all the parts pretty much bolt up? Would I need to do anything to the computer? Thanks guys.... Also, the convertible is bored .30 over too.
everything will bolt up... but you will need to cut the hole in the trans tunnel larger for the manual shifter in the vert....
and you need to swap over the computers as well, the A9P, from the auto car, will not work if you put a manual in it, but the A9L (manual ECC) will work in an automatic car...
Matt's 95 Stang
10-05-2015 07:16 AM
treesloth
09-28-2015 07:03 AM
