Last edit by: IB Advertising
Browse all: Interior Guides
- Ford Mustang V6 1994 to 2004 How to Replace Interior Door Handle
Step by step instructions for do-it-yourself repairs
How do I replace my door handle?
My passenger side door handle is gone. Anyone has a write up on how to replace it?
I think I need to drill out the rivets (which I've never done before) and then connect and rivet in the new?
Anyone have instructions?
You can drill them.. If drilling then I would punch out the center with like a punch first then fit the drill bit so the dill wont walk on you then and scratch your paint.. Then do like mjr46 said linkage then you need a rivet gun.
I just did this and it was easy.Drilled out old rivets while holding handle up.Instead of using rivets to reinstall I used black button head allen bolts w/nut and washer on inside and it turned out great,just in case I have to take off again on my freshly painted door drilling would make me nervous,even tho I do have a rivet gun and the rivets.
Opening from the inside is a linkage issue, in my experience anyway...
Pull your door panel and look for some bent rod kinda stuff.
I used carriage bolts instead of rivets to install the new handles. Make sure you buy METAL handles... and not the plastic replacements.
Using the carriage bolts meant I had to square up the holes, but a little time with a small hand file took care of that...
jason
jason
