Ok just bought a 347 stroker with a powerdyne set at 9 psi, mild cam, cobra intake, and trickflow heads. The car has a valve train knock how do you adjust them?compression? then when you get on it, it sometime try to bog out. what is causing it.
thanks for any info
daniel
White-Lightning...I have a lot of Experience with Powerdyne SC's....First thing you need to check is your timing, based on only getting 91 oct., I would not go any higher then 10 deg. of timing...Also, what fuel injectors, pump & fuel pressure are you running??
I would think 30-36# injectors would be the min. ...I'm leaning more towards the 36ers with the 347...
