How to break in new clutch/flywheel
I picked up my mustang today after having a new centerforce clutch and flywheel installed and I'm trying to figure out if there is any special way to break in the pair aside from driving it gently for 500-600 miles. Also, I am getting some chatter and vibration when I accelerate above 2500 but it goes away when I shift up. Is this normal?
The break-in peroid sounds good...I also vary the speeds...as far as the vibration & chatter...that's not normal IMO...was the flywheel new or turned? ...I also wonder if the driveshaft was bolted with the orig. 4 bolts holes on the rear shaft? ....if it keeps up, bring it back to the installer and that them for a ride.
I drove it again today and the chatter only happens around 2500-3000 but if I get above that accelerating smoothly it goes away. I can tell that the clutch was replaced because it is adjusted all the way down. Also, flywheel was new.Any ideas?
jwog666
12-27-2021 08:09 PM
treesloth
09-28-2015 07:03 AM
ccdguy
09-19-2015 05:20 PM
