XE 264 HR AND LIFTERS questions ?
I just orderd my heads cam and intake and have a question about installing new ford racing roller lifters do I have to let them soak before I install them to check for push rod length or just lube them with assembley lube and put them in
also is any body running this cam? XE 264 HR
Since you're only going to install them to check pushrod length, no, you don't. Of course, you cannot use the standard springs for this procedure; you have to use light weight checking springs.
While you're doing that, you can clay the pistons at the same time.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
