Parking brake handle spring reset.
Help! I just installed a SSBC rear disc conversion on my 87 GT. SSBC instructions said nothing about pinning the spring but my Haynes manual does. I didn't read the part about pinning the parking brake spring untill I was installing the new cables....OOPS! Now everything is hooked up and routed properly but the spring needs reset. My Haynes manual said the handle would need removed but gives no procedure for resetting. Alldata said the tighten the adjuster nut...Duh! no nut!
I am assuming the spring lost it's tension on disassembly. When the handle is pulled up the pully that the cable attaches to does not move at all. Advice would be greatly appreciated.
mungodrums
10-07-2015 04:01 AM
09-16-2015 07:53 PM
LivingInThePast
09-16-2015 12:20 PM
09-08-2015 11:50 AM
mungodrums
Suspension
09-07-2015 07:22 PM
