to much spray for engine?
Old 10-23-2008, 06:40 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Originally Posted by 84_302
How do i know when enough spray is enough spray though?
when the block blows up!!!!!!! 2 degrees timing pull for each 50 hp increase of no2 and at 150 hp 1 step colder on plugs
mjr46 is offline
Old 10-23-2008, 08:22 AM
adam1993
adam1993's Avatar
make sure u have a fuel pump that can hanndle it u dont want to run lean on spray a adjustable pressureregulator is a good idea
adam1993 is offline
Old 10-23-2008, 11:46 AM
84_302
84_302's Avatar
id imagine my fuel pump is fine.. i have a fuel cell so its upgraded... how many pounds should it be pushing? right now i think its at 6 or 7... what should be okay for a spray?
84_302 is offline
Old 10-23-2008, 06:53 PM
grnstang
grnstang's Avatar
why not just run 125 and stay there so you dont break anything
grnstang is offline
Old 10-23-2008, 06:55 PM
Jon82387
Jon82387's Avatar
I've got a 150 shot installed in mine, runnin about 10 degrees timing with 1 step colder plugs, nitrous is great just dont get greedy and try make sure your fuel is adequate for the shot. When i first installed my setup i thought i had it all running right i went for the first test run on nos(100shot) ever and i was kinda disapointed. So i went back put in the 150 jets and didnt really feel a difference, i eventually figured out it was never working.
When it did finally work i can tell you i definatly wasn't disapointed and that yes it is somewhat like the movies depending on the shot
Also im not sure how much different its going to be since your runnin carb'd, im sure some other ppl can chime in on that here tho.
Jon82387 is offline
Old 10-23-2008, 11:44 PM
FullAuto
FullAuto's Avatar
I'm curious as to which specific 100-375 kit you're buying. Any kit actually capable of that range, generally isn't a beginner kit and doesn't look like something I'd recommend for your combo.
FullAuto is offline
Old 10-24-2008, 12:29 AM
kweb288
kweb288's Avatar
as long as he has supporting mods, and doesnt go to high it shouldnt be to bad
kweb288 is offline
Old 10-24-2008, 07:36 AM
302army187
302army187's Avatar
a 100shot to me feel's amazing.
but right now my car has days where a 100shot puts you in the seat, and make's you giggle like a little girl, and i have day's where a 100shot feel's like a 50shot.
ive been to chicken sh*t to run a 150 shot on the street, because my transmission has been actin SO bad....
i dynoed my car with a 150shot, it made 311hp and 398.45 ftlbs of trq at the rear wheel's with my transmission sliping at 4200rpm.
after the tranny swap im hoping for 350hp and 450trq to the wheel.
id run 12* base for a 100 shot, 10-8* base for a 150shot.
1 step colder NGK plug's, and the highest octane fuel you can get (pump gas)
good luck, and have fun!
302army187 is offline
Old 10-24-2008, 08:03 AM
5.0kid
5.0kid's Avatar
make sure not to engage the nitrous untill your over 3000 rpm other wise you could have a nitrous back fire through your carb not good. but fun my dad used to run a 300 shot on his 71 demon. thing ran crazy good 9.70's off the trailer. But he fried a few pistons along the way
5.0kid is offline
Old 10-24-2008, 11:54 AM
84_302
84_302's Avatar
Thanks for all the input my kithas extra jets thats why it goes up so high.. it was on a low nine's car but i dont intend to go above 150 or maybe even 125. Thanks for tellin me the rpm range to that was my next question im building a motor this winter hopefully so for now im just putting it on my engine that in the car now just for kicks not trying to really blow anything up..... just yet haha
84_302 is offline
Quick Reply: to much spray for engine?
