Miss Fire, HELP!
Miss Fire, HELP!
this car has been having a plagueing misfire for the better part of almost a year of ownership
its a constant miss at idle... part throttle and WOT
i have replaced...
ECT
ACT
CAP
ROTOR
PLUGS
WIRES (came with new motor, but had them replaced on old motor still did it)
COIL
TFI MODULE
DISTRIBUTER (stock one came with new motor)
BAP
02 SESNORS
TPS (stock) SET AT .96
TIMING CHAIN (double roller on new motor, came like this)
VACCUM IS ROCK STEADY AT 19lbs AT IDLE
FUEL PRESSURE REGULATOR (set at 38 vac off)
CLEANED THE IAC
DELETED EGR (and bought the EGR plug in simulator thing)
TIMING ADJUST MULTIPLE TIMES (10*, 14*, 12* nothing works)
THE WHOLE ****ING ENGINE lol (seriously i swapped out the motor that was doing it orginally with a 87GT motor and it is still doing it)
motor still does it
at idle you can hear the miss, and hte engine runs rough alot of shaking in it... then at throttle it has complete dead spots... and when its cold it will making popping noises and buck under acceleration while its in its dead spot, then it will kick out of it and just have a complete dead spot again.
any help? LOL
i have replaced...
ECT
ACT
CAP
ROTOR
PLUGS
COIL
TFI MODULE
BAP
02 SESNORS
CLEANED THE IAC
motor still does it
any help? LOL
U sure its a miss not that it needs motor mounts? Also did you ever run the car and unplug one at a time each spark plug to see which one doesn't make a difference in the rpm of the motor. Try also a fuel filter. Where u located in new york by the way if u dont mind me asking.
Elmont... border of Queens
Yes i have changed the Fuel Filter. and i have pulled codes...
got codes saying somthing about the EGR think it is code 33
also got codes saying running lean on passanger and driver side banks.
have you checked the injector harness for bad connections/ breakage of any wiring, usually the ford wiggle test can find such= go around and lightly tug on any and all wire harnesses and see if the issue arrises when you get to the prob area in a harness
i havn't tried that but i will do it once it stops be so damn miserable here on LI, realllllllly windy
Only things i have not touched off the top of my head is
Injectors (same ones from the old motor)
Computer (i made sure it was a SD computer)
