Spun Bearing Help!!!!
I think I may have a spun bearing on my 89 5.0
Noise gets less at rev and comes back at idle..
Noise is apparent on any load.
Is this very exp to fix
any suggestions are greatly appreciated
THanks
THanks
Why do you think you spun a bearing? Not running as well? Are you sure it isn't something else?
If it is a spun bearing, you will most likely wipe your crank also. You will have to yank your engine, pull your crank out and get the crank ground, then get new bearings.....basically you should just do a rebuild on the lower. A stock rebuild can be had for less then $1000 if you buy cheaper parts and shop around the machine work, but that all depends on you plan for the car for how cheap you want to go.
I will know for sure this weds when I get a chance to open it up.
I will let you all know what I find. Maybe I will video it so it can be used as a help to someone else
THanks
I will post updates
G
THanks
I will post updates
G
KingRando
10-02-2015 08:06 AM
Offendant
09-23-2015 07:21 PM
ccdguy
09-19-2015 05:20 PM
