Adjustable Pinion Snubber Install
RE: Adjustable Pinion Snubber Install
its rediculously easy. there is only 3 bolts. you pull the 3 bolts that hold the POS stock on in place then use the same 3 factory bolts to put the new one in. then what you can do is with the suspension compressed (i.e. the car is being jacked from the axle) lower the snubber down and see if you can get the pin through a set of holes. if you can, messure how much you have to cut off the snubber so that it is touching or almost touching the pinion when the snubber is always lowered.
i have pics of my install on my web site; http://www.koolpages.com/potatohell/trucks.html the pics are towards the bottom about 3/4 way down
kawiguy827
09-01-2015 07:09 PM
